If/Else Statement + Source Text + Position Coordinates
Paul Connors
on Sep 28, 2016 at 3:04:06 pm
Hi Guys,
I'm trying to write an expression to set the exact X,Y coordinates of a layer based on the Source Text of another layer.
• Text layer named "SETUP"
• Solid named: "S1"
When the source text for "SETUP" says: "Target1" I'd like the position of S1 to be at 760,340.
Here is the expression I have on the position of S1:
input = thisComp.layer("SETUP").text.sourceText;
xPos = if( (input == "Target1") ) 760 else 0;
yPos = if( (input == "Target1") ) 340 else 0;
[xPos, yPos]
In my mind that should be working. But it's not. Haha. I'm getting an error that says: "Error at line 2 in property 'Position' of layer 3 ('S1') in comp 'Positions Test_001'. Illegal use of reserved word., an expression was disabled as a result of an error.
Anyone got any ideas? It'd be greatly appreciated. Thank you!!!
Walter Soyka
Re: If/Else Statement + Source Text + Position Coordinates
on Sep 28, 2016 at 6:57:12 pm
You cannot use an if statement to assign a value like this. If controls flow and does not return a value.
You have two options. One is to use if properly:
if (input == "Target1") xPos = 760 else xPos = 0;
if (input == "Target1") yPos = 340 else yPos = 0;
[xPos, yPos]
The other is to use the ternary conditional operator, which looks like this:
statementForEvaluation ? valueIfTrue : valueIfFalse;
and returns one of the values according to the evaluation of the statement:
xPos = (input == "Target1") ? 760 : 0;
yPos = (input == "Target1") ? 340 : 0;
[xPos, yPos]
Walter Soyka
Paul Connors
on Nov 1, 2016 at 3:32:44 pm
Hi Walter. I'm really sorry for the late reply. Thanks very much for the help with this!
