Script to import footage's folder in a Composition.
Dario De Angelis
on Sep 28, 2016 at 1:26:53 pm
Hi guys, I was trying (helping with some past thread) to write a script to import an entire folder's footage in my composition, but for now i'm only be able to import a single file in my project (and not in composition), can someone help me?
This is the code that I wrote:
var path = "D:/MYFILEPATH/MYFILE.MOV";
var io = new ImportOptions(File(path));
var proj = app.project;
proj.importFile(io)
How can I convert this to import all folder's file and insert it in a specified Comp?
Walter Soyka
Re: Script to import footage's folder in a Composition.
on Sep 28, 2016 at 2:08:30 pm
What's your familiarity with scripting?
Your code imports only a single file, D:/MYFILEPATH/MYFILE.MOV, because that's all that you specify.
Without writing the code, here's a rough list of the steps you have to take:
- Select a folder
- Get a list of all the files in the folder
- Step through the list and import each file into the project, saving a list of the project items you import
- Create or locate a comp
- Add new layers to the comp using the list of new project items as the sources
Walter Soyka
Dario De Angelis
on Sep 28, 2016 at 2:37:23 pm
Not so much familiarity, i'm trying in these day to experiment with expressions and scripts.
I know that my code imports only a single file, but I don't know how to change the path to import all folder files (if I don't write "MYFILE.MOV" at the end of the path, it give me path's error).
I will try to follow your instruction.
Walter Soyka
on Sep 28, 2016 at 2:55:49 pm
[Dario De Angelis] "Not so much familiarity, i'm trying in these day to experiment with expressions and scripts."
The CS6 scripting guide is a tremendous resource:
http://www.adobe.com/devnet/aftereffects.html
For your specific task here, take a look at the "Smart Import.jsx" script that ships with After Effects.
Walter Soyka
