Re Flex Morph Problem with abnormal skip of blending images at the ending of morph.
Hank Huley
on Sep 27, 2016 at 10:24:28 pm
Hi CreativeCommunity :),
I have a problem with the end of a two images morph using RE Flex Morph v4.0 on After CC2015.
Settings seems to be ok... I have my two images and two mask correctly set... Moves are ok.
I set my picture key keyframes with the famous "YesNoNoYes" as shown on every tutorial you can get.
Morph seems to happen well but when i comes one frame before the ending, instead of being smooth, there is one jump or skip on the image blending... the color jumps directly to the color of the final image.
I don't know how to fix that...
Anyone of you having a clue?
Thank you very much for the attention and the help,
Pierre Jasmin
Re: Re Flex Morph Problem with abnormal skip of blending images at the ending of morph.
on Sep 28, 2016 at 2:54:17 am
You might have more luck for an answer on cow RE:Vision Effects - revisionfx forum
Pierre
