Any ideas on a pulsating grid of dots?
noah campeau
on Sep 23, 2016 at 5:26:24 pm
Trying to work out how to create a grid of dots that pulsates in scale across the screen. Something like in this Apple animation...
I thought Form might be able to do it, but haven't found a way! Anyone?
Noah
Walter Soyka
Re: Any ideas on a pulsating grid of dots?
on Sep 23, 2016 at 7:18:51 pm
Do you mean the grid at 1:17?
Yes, Form will do it. You need to use Form's Layer Map feature. This allows you to use a separate layer as a gradient map which influences the size of the Form particles.
Walter Soyka
Syed Iqbal
on Sep 23, 2016 at 9:36:10 pm
Further to what exactly Walter has suggested here, you may find some really useful tutorials on Redgiant's website. Browse through Harry Frank's tuts and you will get a better idea how to accomplish this. Best of luck.
Kalleheikki Kannisto
on Sep 24, 2016 at 7:11:13 am
Yes, Form works for this. Use a Layer map for Size. The main question is how to create that wave layer map, which I did here with polar coordinates.
10612_formdotswave.aep.zip
Senior Graphic Designer
Daniel Waldron
on Sep 24, 2016 at 2:47:37 pm
Check out the Nodes 2 plugin also.
on Sep 24, 2016 at 5:26:26 pm
Dang, just the type of graphics I frequently do. Thanks for the tip! Added to acquisition list.
Daniel Waldron
on Sep 24, 2016 at 6:34:59 pm
It's not a very well-known plugin for some reason, but seems pretty powerful. It's been used on several big-budget films. I've only used version 1, but Nodes 2 appears to have a lot of added features that make it more competitive with Plexus or Form in addition to its unique tools.
noah campeau
on Sep 24, 2016 at 10:18:32 pm
Brilliant! Thanks for the advise all
