Path animation
Diego Ante
Path animation
on Sep 22, 2016 at 8:49:26 pm
I want to know how can I animate wiggly paths like the following:
https://static1.squarespace.com/static/52829097e4b043b800eeef8c/537e5cd4e4b...
I'm not interested in the more complex animations inside of the path as I know it is made with ouroboros, but rather the up and down motion, as if it went up and down a hill.
Thank you for your help!
Greg Gesch
Re: Path animation
on Sep 22, 2016 at 10:29:28 pm
Hi, you could use the Wave Warp effect with a high Wave Width setting.
Roei Tzoref
Re: Path animation
on Sep 23, 2016 at 11:23:10 am
You could try to explore some scripts like
Rubberhose: http://www.battleaxe.co/rubberhose/
Puppettools: http://aescripts.com/puppettools/
Duik: http://rainboxprod.coop/en/tools/duik/
but I think this was probably very carefully keyframe animated in a traditional animation style with almost no automatic process (no plugins or effects). probably with Ae shapes, and I believe that other than the stroke gaps offset, this was all by the hands of a skillful keyframe artist taking the time to make the right timing and movement of the paths. like this guy:
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
Diego Ante
Re: Path animation
on Sep 23, 2016 at 2:08:49 pm
Thank you both! I think the approach is through wave warp! yet still I'll be checking those links.
