Flying broken glasses
Laurence Pesigan
on Sep 22, 2016 at 4:58:18 pm
Hi guys, I'm new to this forum and I just got started on learning some animation editing.
Anyways, I would like to know if this animation is achievable in AE. Is there a preset with similar effect?
Here's the gif
https://gfycat.com/UnhealthyWhimsicalKusimanse
Ali Jassim
Re: Flying broken glasses
on Sep 22, 2016 at 8:42:38 pm
You may achieve a result close to this in AE if you use a third party plugin called Element 3D from the creator http://www.videocopilot.net
Ali
Kalleheikki Kannisto
on Sep 23, 2016 at 5:19:09 am
The Shatter effect will give you something similar. With lots of tweaking you might get it looking realistic. That's the free option.
A complex (but free) option is to use the C4D lite that comes with AE. It is a 3D program, or a light version thereof like the name says.
If you don't mind getting plugins, I would recommend Element 3D. The glow in the center is Optical Flares, also a Video Copilot plugin.
Senior Graphic Designer
Laurence Pesigan
on Sep 23, 2016 at 6:12:28 am
Thanks for all the suggestions! I might try the free option first.
