h.264 frame size constraints
Nicki Glasses
on Sep 21, 2016 at 2:20:29 pm
So here's the issue I'm facing...
I have an AE animation at 9600x1080 rendered out at Pro Res 422. The reason the file is 9600x1080 is we're playing the animation back across 5 screens. The client is playing back from a pc. The goal was is to convert this 9600x1080 ProRes file to a more pc compatible codec. When converting to h.264, looks like there's a size constraint to a width of 4096.
Is there a unconstrained codec that will allow me to convert from the 9600x1080 ProRes that will be compatible playing back from a pc.
Thanks for the help!
Walter Soyka
Re: h.264 frame size constraints
on Sep 21, 2016 at 4:19:02 pm
5-screen, 9600x1080 playback requires one of several playback systems. Each have their own workflows. You need to get more information about the requirements of the playback system you are using.
Walter Soyka
