Multiple Layer Screen types through pre comp?
Ocean Byrne
on Sep 17, 2016 at 12:42:31 am
Is there a way to have a precomp with multiple layers, some of which are set to Screen, some to Add, some to Multiply, and some to Normal - and then have them continue to behave that way on top of whatever the entire precomp gets put above?
Seems like they get screen/add/multiplied onto the bg color inside the precomp, and then that all gets put on top of everything as normal.
Walter Soyka
Re: Multiple Layer Screen types through pre comp?
on Sep 17, 2016 at 1:30:15 am
Yes. To allow layers within precomps to blend with layers in their containing comp, use Collapse Transformations:
https://helpx.adobe.com/after-effects/using/precomposing-nesting-pre-render...
There are caveats. Collapse Transformations changes the render order, so things like masks and effects applied to the precomp layer will not work as you might expect.
Walter Soyka
