Creating a transition between two vectors
ezra hames
on Sep 15, 2016 at 5:13:13 pm
I am wondering if anyone can help.
I'm currently working on a project, where I need a giraffe to move its head from an upright position to the ground.
I've created a vector of the giraffe with its head up and a giraffe with its head down.
What is the best/ most realistic way to combine these two vectors, making a realistic motion?
Thanks in advance.
Kalleheikki Kannisto
Re: Creating a transition between two vectors
on Sep 15, 2016 at 7:00:00 pm
Use a single image and use the puppet tool to move the head.
Senior Graphic Designer
ezra hames
on Sep 15, 2016 at 7:10:01 pm
Thanks for the reply!
I need the 'upright' position to look exactly like the vector and the 'head down' to look exactly like the vector. Is there a way to achieve this using the puppet tool?
Roei Tzoref
on Sep 15, 2016 at 11:41:28 pm
puppet will work on one image. but there are manipulations you could use to make this transition seamless to another image. could you share a screenshot? we could know better what specific suggestions to give based on specific images.
Daniel Waldron
on Sep 15, 2016 at 7:03:46 pm
The most realistic way is to create the frames in between. Obviously that is significantly more work. It sounds like the Puppet Tool is what you are looking for.
