Transparent Stroke
Marcel Scholz
Transparent Stroke
on Sep 15, 2016 at 12:39:35 am
How is it possible to create a transaprent stroke around an object?
____ Layer 1 with Stroke
____ Layer 2 (invinsible at the Stoke of Layer 1 )
____ Layer 2 (vinsible at the Stroke of Layer 1)
Greg Gesch
Re: Transparent Stroke
on Sep 15, 2016 at 12:55:37 am
Hi Marcel, I'm confused about what you want to do. If it is transparent then you cannot see that it is there, so whatever is behind it will show through whether it is there or not. Perhaps you can give an example or explain more clearly?
Marcel Scholz
on Sep 15, 2016 at 1:01:12 am
I have 3 Layers in the stroke of my First layer which is on the top i want to see the third layer
So the stroke of my First layer would make the second layer "invinsible" and the third layer shine through
Greg Gesch
on Sep 15, 2016 at 1:12:18 am
Do you mean the Stroke effect, or the stroke setting on a shape or text layer? Is the stroke moving so as to reveal the 3rd layer bit by bit, or is it fading out?
Marcel Scholz
on Sep 15, 2016 at 1:52:24 am
I use a layerstyle stroke on a Picture ...
I dont know if a stroke is the best Way but what i want to do ist like a gap between my Picture ( a Logo ) and the Background but complet around like a stroke
