Cool effects using a path?
kit webster
on Sep 12, 2016 at 11:41:32 am
I have this path of the FILA logo
I am using stroke to trace around the outline, are there any other effects or techniques I can use to make use of the path? The client would really like to get a 3D effect inside the F, but any cool effects using the shape will work!
It's for this projection mapping installation in a store:
Thanks for any help!
Kalleheikki Kannisto
Re: Cool effects using a path?
on Sep 12, 2016 at 1:41:55 pm
You can do more with the shape layers, such as animating the trim paths value with a filled shape.
You can wiggle paths.
You can duplicate the path and offset it in the Z axis for 3D-type effects.
If you copy the mask path to a null as a motion path, the possibilities become almost endless. You can animate any object to go around the shape, or a light, or a particle emitter.
Senior Graphic Designer
