Colormanagement AfterEffects (AE) to PremierePro (PE) ///// RED-RAW / Linear-workflow
Marius Jerschke
on Sep 9, 2016 at 9:31:22 am
Hello guys,
we have a problem with the colorspace in AE to PE.
The footage we use in the PremierePRO-Cut is RED-RAW in REDcolor4 and REDgamma4. Now we have some VFX-shots which we import as RAW-files to AE and work on them. After work(screenreplacement) we want to render them out as an EXR and use them again in PE.
What is the right way to export them correct for PE? Cause the brightness isnt correct the way we do it.
import RED RAW to AE -> Colorspace HDTV Rec709 -> linearize -> work on it -> render as EXR -> set output-colorspace to Rec709 -> import to PE -> brightness doesnt match????
What is the right way?
Thank you sooooo much !!!!
kind regards
Marius
