Still mask on animated layer
Mark Grafton
on Sep 8, 2016 at 8:47:40 am
Hello,
I've recently made the switch from Apple Motion to AE. I don't find AE as intuitive as Motion but I'm sure it will click into place at some point – I know it's a much more powerful tool.
One thing I can't seem to figure out is masks. I know how to create a mask within a layer but this follows the keyframes already assigned to the shape.
I have a ball (shape layer) that I need to disappear behind a line. If I create a mask, the mask follows the bounce of the ball. How do I create a mask on a separate layer to avoid this? Or is there a way around this?
In Motion you would just create a shape then cmd + Shift + M to turn it into a mask – Simples.
Thanks in advance!
Mark
Walter Soyka
Re: Still mask on animated layer
on Sep 8, 2016 at 10:06:25 am
[Mark Grafton] "I have a ball (shape layer) that I need to disappear behind a line. If I create a mask, the mask follows the bounce of the ball. How do I create a mask on a separate layer to avoid this? Or is there a way around this? In Motion you would just create a shape then cmd + Shift + M to turn it into a mask – Simples."
In Ae, create a shape layer, then use it as a track matte.
https://helpx.adobe.com/after-effects/using/alpha-channels-masks-mattes.htm...
Walter Soyka
Mark Grafton
on Sep 8, 2016 at 10:14:59 am
Thanks mate, I have managed to cheat it via precomp but will try this next time.
