Stamping black data from footage to every frame?
Charlie Keeper
on Sep 7, 2016 at 9:35:12 am
This is a bit tricky to explain, but I've basically got an image which I'm revealing with a piece of footage of ink as a track matte.
However, as the ink passes across the composition, the image is never fully revealed - so what I'm trying to do is take the black data from the first frame of the footage, then on the next frame it will remain while the black data from the second frame appears on top, then the third, etc etc.
Hope that make sense, any help would be really appreciated!
Walter Soyka
Re: Stamping black data from footage to every frame?
on Sep 7, 2016 at 9:57:37 am
Use the Echo effect, with the Minimum operator. Crank up the number of echoes to accommodate the length of the clip.
Walter Soyka
Charlie Keeper
on Sep 7, 2016 at 10:46:14 am
That did it - thanks!
