Creating/duplicating compositions independently
Ryan Hillaby
on Sep 6, 2016 at 6:31:53 pm
Hello,
Im trying to figure out what the best/easiest way is to duplicate my comps/precomps to be independent comps.
To explain my situation, basically im creating hockey player cards. Not like the trading cards, but when you go to a hockey game and a player scores, its a short 10 second animation where the logo comes up with footage of the player and their name. I have a base file or composition finalized to work off of...but i need to duplicate that about 30-40 times for this whole roster of players so that i can do 2 for each player.
The problem im running into is that the composition that im trying to duplicate has a bunch of precomps inside (comps inside of comps inside of comps, etc...) so whenever i try to edit it it ends up messing with the base file.
I need a quick/easy way to duplicate the composition including everything inside so that every element is independent.
Thanks in advance for any help!
Roei Tzoref
Re: Creating/duplicating compositions independently
on Sep 6, 2016 at 7:31:15 pm
you can re-import your project and you will have independent comps. and you can use this script - True Comp Duplicator script here: http://aescripts.com/true-comp-duplicator/
Eric Santiago
on Sep 6, 2016 at 7:50:54 pm
[Roei Tzoref] "you can re-import your project and you will have independent comps. "
This was my fave for years.
I will try that script you posted thanks!
lorin crosby
on Sep 14, 2016 at 6:52:34 pm
Hi, I just got true comp dup. but it isn't duplicating the expressions. I had "update expressions" checked
I am using the latest version of true comp
please help
