CUDA cards queries
chris brett
CUDA cards queries
on Sep 4, 2016 at 5:38:56 pm
Hi there - having a problem getting AE to use all my graphics cards for processing
----previously been running with 3 x gtx580 cards and a quadro ( for monitor preview)
--- just bought a 780TI which is installed with 2 of the previous 580s but AE only uses the 780 for processing.
The Device Manager and the Nvidia Control Panel both register all 3 of these cards but AE does only sees the 780 in prefs/preview/GPU info and if I render a file I can see that one one card is doing any work ( using Afterburner ) - also its obviously too slow.
CUDA is checked on all three items in the Nvidia Control Panel
Two queries please if anyone can comment-------
1 ) Is a GTX780 TI compatible with a GTX580 ?
2 ) Have I missed a button in AE ? ( have checked list in /support files/recognised cuda cards )
Any ideas on this would be much appreciated -- its proving very hard to solve !
------------------------------------------------------------------- chris brett --------
Tero Ahlfors
Re: CUDA cards queries
on Sep 5, 2016 at 4:59:03 pm
AE uses GPU acceleration only for a few select effects. That said if you want to have multiple GPUs installed they need to be of the same make, model and VRAM size.
chris brett
on Sep 5, 2016 at 9:23:19 pm
-- thanks for this Tero -
-- not sure --- depends how you are setup I think
-- I know they all have to be Nvidia cards and I have got ok results mixing 3 x 580s and a quadro -- just wondering if anyone knows if a 780TI is compatible with the 580s instead of the quadro - cant get it to work ATM.
... am on CS6 and always work in ray tracing mode -- think its quicker though this isnt technicaly proven so I could be kidding myself !
-------------------------------------- cheers -----chris ---
Tero Ahlfors
on Sep 6, 2016 at 5:03:01 am
[chris brett] "-- not sure --- depends how you are setup I think"
"If you have multiple GPUs installed, the GPU-accelerated ray-traced 3D renderer will use the CUDA cores on all of them, as long as they are of the same CUDA compute level. After Effects will also use all of the VRAM on the installed GPUs, with the caveat that both cards will be treated as if they each have the amount of VRAM on the card with the lesser amount of VRAM."
https://blogs.adobe.com/creativecloud/gpu-cuda-opengl-features-in-after-eff...
chris brett
on Sep 6, 2016 at 9:57:18 am
-- thanks Tero --- stating to think the 580 will not work with the 780 ---- will continue with mu search -- maybe get another 780 --
----------------------------------- all the best ----- chris ---
