Advice on PrePurchase PC & Specs
Gary Behrend
on Sep 4, 2016 at 2:08:24 pm
I was thinking about buying an Alienware PC model # A51R2-1766SLV made by dell. I currently have a Mac Mini and an older outdated HP use. Through a Friend I can get this new unused Alienware PC for a really really good price ($999 instead of the retail price of $1700). The Specs are Below. On a scale of 1-10 (10 being the best) how well would this PC work with After Effects, ProPremiere, & Rendering? I've tried to do my homework, but would just like some reassurance. I'd rather buy nice than by twice. Your help would be appreciated.
FULL SPECIFICATIONS (not summarized)
GENERAL
- Manufacturer - Dell Alienware
- Series - Area 51
- Model Number - a51R2-1766SLV
VIDEO
- GPU Type - NVIDIA GeForce GTX 970
- Video Memory - 4GB GDDR5
- VR Ready - Yes
- Video Connectors - 1 x HDMI
- This PC Supports 3 Extra Wide Video cards for up to 12K. Unstoppable graphics capabilities can enable a mind-melting 11520x2160 resolution across triple Ultra HD 4K monitors (sold seperately). The new Area-51 is designed to support up to three full-length double-wide graphics cards.
PROCESSOR - Core i7 5820K (3.3GHz)
- CPU Core - Six-Core
- CPU Type - Core i7
- CPU Speed - 5820k (3.3GHz)
- Turbo Boost Speed - Up to 3.6GHz
- Smart Cache - 15MB
- CPU Brand - Intel
- Front Side Bus - QPI 0GT/s
- CPU Socket - LGA 2011-3
- CPUs Installed - 1
- CPUs Supported - 1
MEMORY
- Total Memory - 16GB
- Memory Speed - DDR4-2133
- Memory Slots (Total) - 4
- Form Factor - 288-pin DIMM
- Maximum Memory Supported - 32GB
OPERATING SYSTEM
- Windows 10 Home 64-bit
CASE & MOTHERBOARD
- Case Orientation - Vertical
- Motherboard Chipset - Intel X99 Express
CPU Main Features
- Virtualization Technology
- Hyper-Threading Technology
- Idle States
- Execute Disable Bit
- Thermal Monitoring Technologies
- Intel 64
- Enhanced Intel Speedstep Technology
- Virtualization Technology for Directed I/O
- Intel VT-x with Extended Page Tables
(EPT)
- Intel Identity Protection Technology
- Intel Smart Response Technology
- Intel AES New Instructions
HARD DRIVE
- HD Interface - SATA
- HD Capacity - 2TB
- HD RPM - 7,200 RPM
- HD Configuration - 1 x 2TB
SOLID STATE DRIVE
- SSD Capacity - 128GB
MULTIMEDIA DRIVES
- Optical Drives Included - 1
- Optical Drive - DVDRW
- Optical Drive Specs - Slot-Loading Dual
Layer DVD Burner (DVDRW, CD-RW)
AUDIO
- Audio System - Internal High-Definition
- Audio via Creative Sound Core3D
COMMUNICATIONS
LAN
- Gigabyte LAN
- LAN Data Rate Speed - 10/100/1000Mbps
WLAN
- Intel Dual Band Wireless - AC 7260
- Bluetooth - Bluetooth 4.0
- Wireless Technology - 802.11ac
MEMORY CARD READER
- FRONT/TOP PANEL PORTS
- USB 3.1
- 2 x USB 3.1 (Gen 1 Type-A)
- BACK PANEL PORTS
- USB 2.0
- 4 x USB 2.0 (Type-A)
- USB 3.1
- 4 x USB 3.1 (Gen 1 Type-A)
- LAN RJ45 - 1
- Audio - 5 ports
Here is A Quick Summary Of Specifications:
(FULL Specifications found above)
- Intel Core i7-5820K Processor 3.3GHz
- Microsoft Windows 10 Home 64-bit
- 16GB DDR4-2133 RAM
- 128GB Solid State Drive+2TB 7,200RPM
Hard Drive
- NVIDIA GeForce GTX 970 4GB GDDR5 VR
Ready
- Slot-Loading Dual Layer DVD Burner
- Media Card Reader
- 10/100/1000 Network
- Intel 7260 802.11ac 2x2 Wireless
Tudor "Ted" Jelescu
Re: Advice on PrePurchase PC & Specs
on Sep 4, 2016 at 8:01:02 pm
Having worked on Alienware before I can tell you that they look great, however I was disappointed by the performance - and it was not just my particular machine, there were 6 in our office. Now we have 2 Origin PC and 4 3XS ones that work great, however the price was pretty steep. I have a great machine at home however that did not break the bank, an MSI, with 32 GB RAM, i7, GTX870M. What I love most is a 3 SSD SuperRAID2 setup. That was worth all the money. This rig was under 2500 USD and it's a workhorse. So I guess if you have the funds I would recommend to choose something else, but for the price you can get it at, it may be the machine of choice for you.
Tudor "Ted" Jelescu
Senior VFX Artist
