Moving a layer and moving keyframes from a different layer at the same time
Justin Wood
on Sep 1, 2016 at 8:47:29 am
I have run into this issue a few time so thought it was worth asking...
I have a null layer which controls a camera and then I have other layer with my actual animation on.
If I want to change the timing of my animation slightly then this means I have to manually move all the null object keyframes so the camera is once again moving in time with my animation.
I am just looking for a way to select layers and then select keyframes from the null layer without actually dragging the null layer its self and moving all the keyframes.
Any pointers or tips would be greatly appreciated!
Cheers
Justin
