Glitching render, but not in precomp
Anoek Houben
on Aug 27, 2016 at 11:09:12 am
Hello,
I have a curious problem... I animated a set of circles, and in the precomp everything is fine. Yet, when I put the precomp in my DEF comp, suddenly the animation is glitching? I rendered both my precomp and def, you can watch them below (3 sec animation):
https://drive.google.com/open?id=0B59X54HHyV9bRXRfaE1LSXhNQjA (precomp)
https://drive.google.com/open?id=0B59X54HHyV9bWnVOdlJjM0Z4OWc (def)
As you can see in the def at the end, the circle at the top glitches, but it doesn't do so in the precomp. I simply dragged my precomp in the def, and didn't adjust anything. There are two other layers in the def at the moment, but disabling them doesn't help either; still glitching.
Any thoughts?
Thanks in advance!
Anoek
Walter Soyka
Re: Glitching render, but not in precomp
on Aug 27, 2016 at 11:13:00 am
Try clearing your cache. Edit > Purge > All memory & Disk Cache.
Walter Soyka
Anoek Houben
on Aug 27, 2016 at 11:20:23 am
Thanks for your (super fast) response :)
Unfortunately, clearing the cache doesn't work. Still glitching
Walter Soyka
on Aug 27, 2016 at 11:23:46 am
Can you post the AEP?
Walter Soyka
Anoek Houben
on Aug 27, 2016 at 11:32:39 am
You can find the AEP here:
https://drive.google.com/open?id=0B59X54HHyV9bQVJ6X1RPcnl6aVU
Looking at it now, I think it has something to do with the mask applied to the layer named "cirkel_stuk1" in the "cirkel_swirls" comp. It glitches in the def at the time the mask in the "cirkel_swirls" comp expands.
Walter Soyka
on Aug 27, 2016 at 11:57:37 am
You have a frame rate mismatch. DEF is 29.97, and cirkel_swirls is 25.0. I think the keyframing on the mask in 25.0 is not lining up in 29.97.
Walter Soyka
Anoek Houben
on Aug 27, 2016 at 12:07:11 pm
Unfortunately, after changing the FPS in the def comp (and once again clearing cache), it still glitches.
Thanks for pointing it out though! Didn't notice it, and it can be problematic in the future.
Anoek Houben
on Aug 27, 2016 at 12:09:37 pm
Oh!
It did fix it! I deleted the precomp in the def, and put it back in, and now it is fixed!
Thanks for your help :)
