How do i edit out a person from a another video to insert the person to another background?
Christopher Khouri
on Aug 27, 2016 at 9:57:30 am
As the title says how do i edit out a person from a another video to insert the person to another background?
Walter Soyka
Re: How do i edit out a person from a another video to insert the person to another background?
on Aug 27, 2016 at 11:10:36 am
You need to isolate the person from their background by either keying [link] or masking [link].
When planning ahead for this, you record the person in front of an evenly-lit green or blue screen. This makes keying straightforward and practical. Without a background designed for chroma keying, you'll have to animate masks over the person, tweaking them on every single frame. This is called rotoscoping [link], and it's laborious. Ae has some tools called Roto Brush, Refine Edge, and Refine Matte which can help quite a lot with this task. Be sure to read the Roto Brush documentation [link] before you start, as it can be a bit tricky to use.
Walter Soyka
Christopher Khouri
on Aug 27, 2016 at 1:03:38 pm
Thank you for the answer. I will try learning how to use the roto brush :)
