Animate a trace line around an object
Ashley Davis
on Aug 24, 2016 at 11:10:30 am
I have an aerial image of a skyline and I want to animate a line to trace around a particular building. What is the easiest way of doing this?
John Cuevas
Re: Animate a trace line around an object
on Aug 24, 2016 at 12:51:46 pm
Trace a mask around the buildings you want to animate then add the effect Generate > Stroke and set it's Paint Style to "On Original Image". Keyframe the end point.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
