Lines Creator?
nick van horn
Lines Creator?
on Aug 23, 2016 at 9:54:48 pm
Can some one identify the line effect used to create and transition between shapes used in this video?
I was wondering if it could be done with Lines Creator or if there is another effect,script or plugin that can generate the effect?
Thank you!
nick van horn
Re: Lines Creator?
on Aug 24, 2016 at 3:42:50 am
Sorry about the repeat.
Tudor "Ted" Jelescu
Re: Lines Creator?
on Aug 24, 2016 at 6:37:55 am
I am not aware of a plugin that can do the complex transitions in your example. Most likely it was done using well planned elements and animated masks or wipes.
Tudor "Ted" Jelescu
Senior VFX Artist
