Explode/Shatter a low poly drawing and reassemble
Mark Retzloff
on Aug 22, 2016 at 5:00:53 pm
Hello All,
I'm looking for a way to animate/explode/shatter the pieces of a low poly drawing and then reassemble it OR better yet, reassemble it as another image. So the pieces would come apart and then come back together as a different image. Open to any solution.
One of the low poly images is here: 10459_africangirlwithglass1.png.zip
Thank you,
Mark
Michael Szalapski
Re: Explode/Shatter a low poly drawing and reassemble
on Aug 22, 2016 at 8:32:47 pm
As mentioned in this thread, it would be a good idea to recolor those polys and use them as a custom shatter map for the Shatter effect. :)
- The Great Szalam
