Trapcode Form point cloud export
peter kovalik
on Aug 19, 2016 at 11:36:19 pm
Is it possible to export point cloud info as an OBJ so it can be re-imported for use in Plexus? Or simply put, is there a way for Plexus to read particle info from Trapcode Form?
It doesn't matter if it's a plug-in, a script or some convoluted workaround. I just would like it to work somehow.
Thank you
petklik
Kalle Kannisto
Re: Trapcode Form point cloud export
on Aug 20, 2016 at 8:13:54 am
3d camera tracking and creating 3d nulls comes to mind first. Special case, limited workability.
Kalleheikki Kannisto
Senior Graphic Designer
