How can you move a layer/object but keep the mask still?
Josh Rod
on Aug 16, 2016 at 7:09:13 pm
I got a shape that i want to appear from a mask. But when i move the shape the mask moves with it.
I could just use another shape that matches the colour of the background. But using masks would be so much easy and less layered.
pls help this should be so simple. Alot of the tutorials are quite old so i thought of asking again.
Michael Szalapski
Re: How can you move a layer/object but keep the mask still?
on Aug 16, 2016 at 7:19:56 pm
Put the mask on a second layer and use it as a track matte.
- The Great Szalam
Josh Rod
on Aug 16, 2016 at 9:15:27 pm
Can you explain the in more detail please.
Do i make a new layer and put the mask on that ?
Greg Gesch
on Aug 17, 2016 at 3:15:11 am
Hi. Yes, make a white solid and paste your mask (make sure the white solid is above your other layer). In your comp panel on the right of the layer name you should see parent/mode/TrkMat(for track matte), under TrkMat you should set the dropdown to Luma. This means that only where the white is will any image appear. If you can't see TrkMat heading press the Toggle Switches button on the bottom of the panel. Track Mattes are really useful and worth learning a bit about.
Tero Ahlfors
on Aug 17, 2016 at 7:35:27 am
You could also use the pan behind tool.
