How to zoom out off a map with video clips?
Nitai Lev-Oren
on Aug 16, 2016 at 11:29:10 am
Hi I have a comp with video co pilot tutorial of earth zoom out and I'm trying to put clips on the comp but they are floating on the map when I'm zooming out.
Kalle Kannisto
Re: How to zoom out off a map with video clips?
on Aug 16, 2016 at 1:57:44 pm
As I (vaguely) recall, there was a master null (or layer) for scale that everything was parented to. Did you parent the videos to the same?
Kalleheikki Kannisto
Senior Graphic Designer
Nitai Lev-Oren
on Aug 16, 2016 at 4:07:48 pm
yes I attached all the clips to a null object but I don't want the clips nor the comp will be 3d
here is a pic:
Dave LaRonde
on Aug 16, 2016 at 5:13:55 pm
The following trick MIGHT work. No guarantees: put the map in a precomp as a 2D layer, and put the video layers above it in the timeline. Need to transition to a new map? do it in the precomp.
But I don't know if that'll work well for you. Not familiar with the tutorial.
Dave LaRonde
Promotion Producer
Nitai Lev-Oren
on Aug 16, 2016 at 6:59:47 pm
and here is a video from what I see:
http://screencast.com/t/4THUaN9fnZo
Nitai Lev-Oren
on Aug 18, 2016 at 11:00:14 am
up
Kalle Kannisto
on Aug 19, 2016 at 6:34:54 am
The only problem I see is that the videos are not connected to the main null.
Nitai Lev-Oren
on Aug 19, 2016 at 10:32:55 am
videos you mean the v.clips on the map or the map pics PNG files?
Kalle Kannisto
on Aug 19, 2016 at 3:32:43 pm
By video I mean video. "Clips2" is parented to "clips" and "clips" is not parented to anything. Whichever layer contains your video clips -- or both -- should be parented to "null6" if that's the master scale null.
Rex Payne
on Aug 18, 2016 at 4:46:29 pm
http://www.bmyers.com/public/Zoom_to_Location_video.cfm
