Alpha needs to be solid and not look like RGB.
Justin Mettam
on Aug 15, 2016 at 8:40:32 pm
I am trying to create a sphere by blurring a circular mask then using the same mask to cut out the blur. This works well in RGB but the Alpha looks the same as the rgb. How can I make the alpha a solid white circle while keep the rgb feeling spherical.
See attached image of my simple AE comp stack.
Walter Soyka
Re: Alpha needs to be solid and not look like RGB.
on Aug 15, 2016 at 9:18:02 pm
How about a single solid layer, cut with a circular mask, consisting of a Gradient Ramp set to radial, plus Curves or Levels to tweak?
Or an Inner Shadow layer style?
Or a black circle below your stack there, not cut with the blurred version?
Walter Soyka
Justin Mettam
on Aug 16, 2016 at 4:26:46 am
Thanks for responding Walter. Your ideas have given me something to work with.
Is there a way to make a normal map (in AE) out of a photo or a grey shaded graphic? I
Justin Mettam
PreViz & 3D-Generalist
mettam@hotmail.com
415 261-7633
http://www.JustinMettam.com
Kalle Kannisto
on Aug 16, 2016 at 8:32:37 am
You can also adjust alpha channel only with curves.
Kalleheikki Kannisto
Senior Graphic Designer
Darby Edelen
on Aug 23, 2016 at 8:44:56 pm
[Justin Mettam] "Is there a way to make a normal map (in AE) out of a photo or a grey shaded graphic? I"
You can kind of get close by using Emboss, Shift Channels and the Add blend mode. Unfortunately AE lacks the tools to perform normalization on the resulting color values. Perhaps there's a 3rd party solution.
Darby Edelen
