How to create real 3D stroke/beam in AE (What follows light path?)
Max Khachykian
on Aug 15, 2016 at 5:32:12 pm
So I basically have point A and point B that are in 3D space that I need to connect with a line/beam/stroke/cabel.
I came up with particular following point light path but it has not best controls, as I need to rename manually ALOT to follow the light path that I need preoperly.
Do you know if there is any pluging or effect that can simply follow the light path? or mby I can make a light beam to not effect object but just shine with color i need?
Or can I create a 3D path for 3D stroke somehow?
Thanks in advance, folks!
Kalle Kannisto
Re: How to create real 3D stroke/beam in AE (What follows light path?)
on Aug 15, 2016 at 6:57:15 pm
There is always Trapcode 3D Stroke:
https://www.redgiant.com/products/trapcode-3d-stroke/
Kalleheikki Kannisto
Senior Graphic Designer
