3D Layers - Rendering Issue
Nathan Wilkes
on Aug 13, 2016 at 7:19:31 pm
Hey everyone,
I'm having a slight issue with the 3D Layers in Adobe After Effects CC 2015. I've got a pretty simple 3D Comp set up and when I go to render it, one layer has pretty much moved to a completely different place. When I look at it in preview, it's fine however when I render, it changes. If I render the sequence out as a JPG, it's not an issue but I can't really do that for this project. I'm using the ray-traced camera as I needed to do some fancy 3D-ness with it. Anyone got any ideas?
Thank you in advance for your help :D
Walter Soyka
Re: 3D Layers - Rendering Issue
on Aug 14, 2016 at 9:18:49 am
Have you tried clearing your cache before rendering?
Edit > Purge > All memory & disk cache
Walter Soyka
Nathan Wilkes
on Aug 14, 2016 at 9:30:33 am
I'm afraid I have. Did it again just now and still getting the same thing.
Walter Soyka
on Aug 15, 2016 at 9:33:31 am
[Nathan Wilkes] "When I look at it in preview, it's fine however when I render, it changes. "
Normally, this means that you're looking through some view other than the active camera. But this...
[Nathan Wilkes] "If I render the sequence out as a JPG, it's not an issue"
... has me confused. The renderer's output should not change with the format. Are there any other variables changing there?
Can you post some screenshots?
Walter Soyka
