Change Render Settings in a Script
Geoff Rights
on Aug 11, 2016 at 8:46:58 pm
Hey All,
I was able to create an item for the render queue using this syntax:
var renderItem = currentProject.renderQueue.items.add(currentComp);
How do I access the render settings of that render item and change the resolution output of the render to a third? I haven't had any of these work:
renderItem.resolutionFactor = [.33,.33];
renderItem.renderSettings[1].resolutionFactor = [.33, .33];
renderItem.renderSettings.resolutionFactor = [.33,.33];
Thanks for any help.
Walter Soyka
Re: Change Render Settings in a Script
on Aug 12, 2016 at 12:16:44 am
Access to render settings works way differently than you might expect. See "scripting access to render settings and output module settings" on this page for some code examples:
https://blogs.adobe.com/creativecloud/new-changed-after-effects-cc-2014/?se...
Walter Soyka
Geoff Rights
on Aug 12, 2016 at 12:56:45 pm
Thanks Walter. This read helped a lot.
Walter Soyka
on Aug 12, 2016 at 1:01:28 pm
Cheers, Geoff. Before this scripting feature was added, I used to manually build templates and distribute them to the team, then use scripting to set them as needed. That may be another option for you.
Walter Soyka
