Transition (Moving Object in Video)
Frank Strohkirchen
on Aug 9, 2016 at 7:43:15 pm
I'd like to make a transition like the one in this video after 8 seconds:
If you move an object out of the video the following video should already play. I haven't found any tutorial on youtube. Can someone direct me to a tutorial or at least say how such a transition is called.
Thanks for your help!
Sean Dunn
Re: Transition (Moving Object in Video)
on Aug 9, 2016 at 9:01:00 pm
It's fairly easy, it's using masks to show the video layer underneath as the top tray is pulled away.
I'm busy currently, but later I can make a quick demo if masking doesn't work.
Dave LaRonde
on Aug 9, 2016 at 9:26:44 pm
Yeah, just animate a mask. It should be pretty easy, and go fairly quickly. It's not complicated at all.
Dave LaRonde
Promotion Producer
Kalle Kannisto
on Aug 10, 2016 at 8:58:23 am
Note that you don't move the desk in the original shot, you just have the person grab the edges and stop. You add the pulling motion in AE.
Kalleheikki Kannisto
Senior Graphic Designer
Frank Strohkirchen
on Aug 10, 2016 at 5:22:27 pm
Thanks for your help! I have seen that it is also possible to make a mask in premiere pro. Now if I use the free draw brezier or any other form, my "track selected mask forward" button isn't working.
Is there an easy fix for this?
Sean Dunn
on Aug 10, 2016 at 5:45:29 pm
Could you specify how it's not working? Is the button grayed out? Do you have the mask selected while trying to track?
Frank Strohkirchen
on Aug 10, 2016 at 7:07:12 pm
Exactly, the button is grayed out. I attached a print screen.
http://i1318.photobucket.com/albums/t650/stroh4/Bildschirmfoto%202016-08-10...
Sean Dunn
on Aug 10, 2016 at 7:30:19 pm
Ah, yea for that all you should have to do is click on Mask 1 and it should light up.
