Bulge effect on text
Lisa Olshanski
on Aug 9, 2016 at 7:24:48 pm
Hi All- I am using a bulge effect on text to make it look like it's going around a horizontal cylinder. It is making my text look really weird. See attached. The type is a vector file from photoshop scaled down to 35% in AfterEffects. I put a 10% blur on the text to try to cut down on the bulge effect weirdness. Look closely at the edges and some circular thing going on. Any thoughts?
MacBook Pro- Mac OS ver. 10.10.3- Processor 2.5GHz- 16GB memory
Final Cut 7
Adobe Premiere CC
Sean Dunn
Re: Bulge effect on text
on Aug 9, 2016 at 7:36:52 pm
Here's a pretty decent tutorial on how to do what you described using CC Cylinder instead of the bulge.
Lisa Olshanski
on Aug 9, 2016 at 7:47:05 pm
Thanks Sean. I tried that. I need the type to move kind of like an odometer or slot machine. Not individual numbers moving but all the type moving around a cylinder in that direction. Thanks though!
Final Cut 7
Adobe Premiere CC
Lisa Olshanski
on Aug 9, 2016 at 8:17:00 pm
Hi again Sean- I figured out how to do that but it doesn't give me the nice effect I get with Bulge.
Final Cut 7
Adobe Premiere CC
Sean Dunn
on Aug 9, 2016 at 8:40:49 pm
Ah okay, sorry I misread as needing help with the initial effects.
For the weird dots, did you double check for the continuous rasterize button? Possibly use a illustrator vector file instead of a photoshop one?
