Trapcode install issue
Allen Blaine
on Aug 6, 2016 at 6:53:53 am
Forgive me, as my search did not find anything new pertaining to my editions of software.
I am trying to install Trapcode Particular 2.5, to use with my Windows 7 machine that I just had built, along with After Affects CC2015(I have the whole Adobe Suite.) After loading Trapcode Particular, it does not appear in AE CC2015. The directions that are include are not very clear, as they reference loading it with CS4 or CS5, even though I downloaded the CC2015. It alos made mention in the instructions to load it in XP compatibility mode if on a Vista or Win 7 machine. Yet, when I tried that, it gave me an error message stating it cannot be done with CS5 or higher. I also tried running it in Win7 compatibility mode, but had no lucky with it showing up in AE.
Can anyone tell me where I can load the setup files and then load/install, so it works properly? I found nothing on the interwebs either. :(
Thank you
Kalle Kannisto
Re: Trapcode install issue
on Aug 6, 2016 at 8:24:18 am
See link in Trapcode forum.
Kalleheikki Kannisto
Senior Graphic Designer
Allen Blaine
on Aug 7, 2016 at 5:24:15 pm
Okay, thank you.
