how to control duplication layer with slider control in after effects
Suniel Surya
on Aug 5, 2016 at 4:41:46 pm
Hi Guys !!
I'm Working With Simple 3D Project.. i'm Creating A 3D Box Layer... with this script ( value + [0,0,index] )
but i want to control layer duplication with Slider Control is it Possible
even i increase the value in slider control then layers will automatically duplicate based the value ... is it possible friends
P.Surya Suniel
Editor,Siticable
Admin,http://www.tutofactory.com
Michael Szalapski
Re: how to control duplication layer with slider control in after effects
on Aug 5, 2016 at 7:50:06 pm
You couldn't control the number of layers with a slider, but you could control the opacity of a bunch of duplicates with a slider to achieve a similar result.
The opacity expression you'd need to create would be significantly longer than the one you're currently using for position!
- The Great Szalam
