how to: "camera lock" effect? h-e-l-p
Amitay Leopold
on Aug 3, 2016 at 12:41:06 pm
Hi everyone,
I need some technical help on how to:
I have an idea for a video, which is shooting someone playing the guitar and adjusting some anchor points(say his hand) with a green dot, and lock the dot or any other object with the green dot to a specific position in the comp. which will cause the object to stay where i wanted it to be, and the video will follow it.
For example: https://vimeo.com/9322991
All the best,
Leopold
Kalle Kannisto
Re: how to: "camera lock" effect? h-e-l-p
on Aug 4, 2016 at 7:54:54 am
With that much motion, the ball was probably manually tracked frame by frame and then the shot stabilized around it, enlarged so that the the frame edges are not showing.
