Installing the Dojo tool kit script
Justin Mettam
on Aug 1, 2016 at 5:21:15 am
I downloaded the Dojo_tool kit scripts.
I have never installed scripts before.
The downloaded file once unzipped contains a folder structure with many scripts inside. I copied the main folder dojo release 1.11.2 to my
C:\Program Files\Adobe\Adobe After Effects CS6\Support Files\Scripts\ScriptUI Panels\dojo-release-1.11.2
Now when I run AE-CS6 and go to Window I dont see the Dojo scripts listed there.
What am I doing wrong, can anyone help help me with this ?
Thanks in advance.
Justin Mettam
PreViz & 3D-Generalist
mettam@hotmail.com
415 261-7633
http://www.JustinMettam.com
Jim Scott
Re: Installing the Dojo tool kit script
on Aug 1, 2016 at 2:35:59 pm
Normally there should only be a .jsxbin file that goes in your ScriptsUI Panels folder. Are the other files that you say are "scripts" actually multiple .jsx files, or something else? If you do have version 1.11, that is an earlier version and may have just been separate scripts that should all go in your Scripts folder and would then appear in your File>Scripts menu. On the Creative Dojo site I see that he is up to version 2.2 of the Dojo Toolkit, so you might just want to get the latest one. In any case, if you can't get it sorted out contact VinhSon at Creative Dojo.
Hope this helps.
