AE Renderfarm?
Tom Segura
AE Renderfarm?
on Jul 28, 2016 at 6:50:16 pm
Good evening everybody,
I'm handling a pretty complex project in AE. Right now for about 20 seconds of output it takes about 9 hours to render and I must render about 2 hours of footages.
I have two macs, a quad core iMac 4ghz and a MacPro 12core 2.7ghz. Both with 32GB ram and I ended up to use the iMac because it renders much faster without using multiprocessing (which is by the way disabled in the latest version of AE). And even with multiprocessing the render time per frame was anyway slower on the 12core.
So.. my question is. Do you know guys if there's any way to add extra external CPU and use them as a render farm for AE? At first i thought togged some mac mini ad use them as a render farm. But I'm not expert at all in this field an probably it's a bad idea.
Do you have ANY suggestion? Thanks in advance and congrats for this great forum.
Mario
PS: The project is well built... the time required to render is not the result of absurd use of effects or infinite nested comps etc.. the time required is normal because of the resolution and the amount of post/VFX...
Walter Soyka
Re: AE Renderfarm?
on Jul 28, 2016 at 7:52:45 pm
Ae CC 2014 has support for naive network rendering:
https://helpx.adobe.com/after-effects/using/automated-rendering-network-ren...
I've written extensively about Ae's network rendering here in this forum -- a quick search should turn up my notes.
I'd suggest you look into a proper render manager like Deadline or Tractor. I'd also suggest that Mac Minis are probably very inefficient in terms of cost/performance.
Walter Soyka
Tom Segura
Re: AE Renderfarm?
on Jul 29, 2016 at 8:23:11 am
Thank you very much for the quick reply Walter,
I found your articles/notes. I'll read them soon and eventually, if you're available, get back to you if something is not clear to me.
Talk soon
Mario
Lisa Adess
Re: AE Renderfarm?
on Jun 21, 2018 at 4:28:57 pm
Hi Walter,
i know this post is over 2 years now but i was looking for some knowledge on setting up a local renderfarm for AE rendering.
i am automating the render of about 700 one-minute-long videos per day out of AE. nothing too complex but obviously the volume requires some renderfarm workflow.
i looked into the network rendering option in AE but all over i see that it has to be exported as an image sequence. My question is, is that the only output format? does that mean i cant use it if my video has audio?
thank you in advance,
Lisa
Walter Soyka
Re: AE Renderfarm?
on Jun 25, 2018 at 9:27:50 am
[Lisa Adess] "i looked into the network rendering option in AE but all over i see that it has to be exported as an image sequence. My question is, is that the only output format? does that mean i cant use it if my video has audio? "
See point number 3 in my notes:
https://forums.creativecow.net/thread/2/1119178#1119205
You can export audio, but only from a single machine. By setting up a post-render action, you should be able to handle the audio and stitching.
Maybe look at Render Garden? It's new this year and should solve a number of your problems pretty easily.
https://www.mekajiki.com/rendergarden/
Walter Soyka
Lisa Adess
Re: AE Renderfarm?
on Jun 25, 2018 at 1:21:06 pm
Thank you for your clear answer.
rendergarden looks like an awesome option either way and not too costly as well thought i'm not sure its going to be powerful enought for our need.
if im looking to render out 700 one-minute video with effects PER DAY, do you think there is anyway to do that without a render farm?
i'm not against renderfarms just have no knowledge about setting one up so i'm kinda lost...
Walter Soyka
Re: AE Renderfarm?
on Jun 25, 2018 at 2:09:59 pm
[Lisa Adess] "if im looking to render out 700 one-minute video with effects PER DAY, do you think there is anyway to do that without a render farm?"
Sorry, I assumed that you already had a network of computers set up, since you were talking about the watch folder network render system.
I understand what you're trying to do... but what is it exactly that you've already got to work with?
Walter Soyka
