How to import camera data
Eszter Olah
on Jul 27, 2016 at 2:47:14 pm
Dear All,
I am learning AE from a book wich tutors the AE 6.0 but I use AE CS6. According to the book's instructions i try to import a camera data wich is in a txt fie to a camera layer using Ctrl+C and Ctrl+V but it not works. How can i solve this problem? It seems that what worked in AE 6.0 may not work anymore in AE CS6.
Thank you for your kinde help!
Eszter
Walter Soyka
Re: How to import camera data
on Jul 27, 2016 at 8:45:54 pm
This will still work if the data is formatted correctly.
The last time the keyframe clipboard data format was adjusted was CS3. If you are trying to use data the pre-dates CS3, it may not be in the correct format for Ae CS6 (or Ae CC 2015, for that matter).
Walter Soyka
