Flickering/Jitter in Solid Colors
Joel Smith
on Jul 26, 2016 at 5:59:54 pm
I've run into an interesting problem and I can't figure out why it's happening.
I have a series of solid circles slowly moving across the screen. I have a solid color below/behind them. The solids gradually get transparent as the move, revealing the color underneath.
Example: https://vimeo.com/176349329/23704528ce (I know the example is red and not super high quality, but the flicker is on the original ProRes render)
The problem is there is a flickering to the solids when they get to the halfway point in the transition.
What I've done:
• Rendered from a 16 bit and 32 bit project
• Rendered to ProRes 422 HQ and ProRes 4444
• Changed speeds (fast or slow, it does the same thing)
• Uninstalled and reinstalled After Effects, clearing all preferences
• Rendered from CC 2014 and CC 2015
• Added a texture/grain over the whole composition
No matter what I do, the flicker is still there. Any thoughts of what I'm missing?
