Looping an expression
Ryan Jones
on Jul 26, 2016 at 3:57:20 pm
Greetings all,
Basically, I have the usual "bounce" expression on a shape layer. So three keyframes; 0, 100 and back to 0. This makes the box go up and then back down with a "bounce" when it hits the last keyframe 0.
What I'd like is to add the LoopOut expression so that it is always going up/down (with a pause so fourth keyframe for the loopOut) and also includes the bounce. Right now it only bounces on the three keyframes and after that, it's just up/down with no bounce. Is this even possible?
Thanks all!
Walter Soyka
Re: Looping an expression
on Jul 26, 2016 at 5:45:59 pm
You cannot apply two expressions to the same property. I see a couple quick-ish options:
1) You can rewrite your bounce expression and make it loopable.
2) You can precomp your shape layer with the bounce animation and loop it via time-remapping.
Walter Soyka
Ryan Jones
on Jul 26, 2016 at 5:51:41 pm
I figured as much LOL. I keep forgetting AE isn't C++. I do like option #2. I greatly appreciate your help.
