Video Rendering
Dada Kräuter
Video Rendering
on Jul 25, 2016 at 10:05:04 am
Hello, :)
I made a project in 4K resolution. I wanted to render it in 540p. Created a new composition(960x540) and scaled my project to 25% to fit everything in. When I render it in MP4, it takes same time as 4K. But final quality is really bad...
What does that mean? How can I fix that if that's a problem?
Best regards,
DADA
Walter Soyka
Re: Video Rendering
on Jul 25, 2016 at 12:25:44 pm
[Dada Kräuter] "I made a project in 4K resolution. I wanted to render it in 540p. Created a new composition(960x540) and scaled my project to 25% to fit everything in. When I render it in MP4, it takes same time as 4K. But final quality is really bad..."
With this setup, Ae is calculating the entire 4K frame, then scaling that down to 25%. If you want to render directly to 540p, add your 4K comp to the render queue. By default, Ae will set the render settings to Best Settings in the render queue. Click on Best Settings and set the resolution to Quarter. Be aware that this may impact the look of some effects.
What is your process for rendering to MP4? In what way does it look bad? Scaling down does mean throwing away a lot of detail, and some content is not well-suited for this.
Walter Soyka
Dada Kräuter
Re: Video Rendering
on Jul 25, 2016 at 12:49:58 pm
Thank you for your reply, :)
"In what way does it look bad?"
It's to much pixelated. But when I render one frame(JPEG) in 540p, it look good...
Thanks again!
Dave LaRonde
Re: Video Rendering
on Jul 25, 2016 at 1:21:01 pm
It could mean that you are rendering at a very low bit rate. It could also mean that you are judging the rendered animation while the viewer is paused.
Dave LaRonde
Promotion Producer
Dada Kräuter
Re: Video Rendering
on Jul 25, 2016 at 1:28:28 pm
Thanks for reply, :)
"It could mean that you are rendering at a very low bit rate."
Target bitrate is set to 40.
Maximum bitrate is set to 50.
So... :\
"It could also mean that you are judging the rendered animation while the viewer is paused."
Sorry, but I don't understand what do you mean. I leave it on render, then come back and watch rendered video... Nothing else.
Thanks again!
Dave LaRonde
Re: Video Rendering
on Jul 25, 2016 at 2:56:52 pm
40 what? 50 what? KB? MB? One means too low a bit rate. The other indicates a problem.
Dave LaRonde
Promotion Producer
Dada Kräuter
Re: Video Rendering
on Jul 25, 2016 at 4:02:43 pm
40-50 [Mbps]
Dave LaRonde
Re: Video Rendering
on Jul 25, 2016 at 5:08:29 pm
Please take the time to render out the animation in something other than H.264. I suggest the Photo JPEG codec in Quicktime. How does the animation look?
Dave LaRonde
Promotion Producer
Dada Kräuter
Re: Video Rendering
on Jul 25, 2016 at 5:35:40 pm
"How does the animation look?"
It looks same as H.264 version... :\
Taylor Higgins
Re: Video Rendering
on Jul 25, 2016 at 5:22:15 pm
Add 4k vid to render queue click "output Module"(where it usually says lossless), tick the resize and plugin your resolution. 50MBS should be just fine. Not sure how you are calculating your downscaling but here is a resolution calculator - https://bneijt.nl/pr/resolution-scale-calculator/.
Good luck.
