auto-scrolling text if text exceeds text box
Tim Jansen
on Jul 23, 2016 at 9:11:54 pm
hi all,
is it possible to automatically add a scrolling animation to a text if (and only if!) the text is bigger than the text box?
as as example, let's say i have a text box in my comp with a set size and it shows descriptions of something. some description-texts fit inside the set text box, while other texts are bigger than the text box itself (the text gets cut off at the buttom). if that happens, i'd like the text to scroll up so the rest of the text is eventually shows.
is that possible?
thank you all for reading and your time.
regards
tim
Kalle Kannisto
Re: auto-scrolling text if text exceeds text box
on Jul 24, 2016 at 7:09:45 am
Premiere's rolling credits might work for that.
Tim Jansen
on Jul 24, 2016 at 10:33:03 am
hey thanks for the quick reply.
any way of doing that kind of thing directly in after effects though? like some clever expression that handles that case?
thanks for your time
tim
Kalle Kannisto
on Jul 24, 2016 at 12:36:40 pm
sourceRectAtTime can retrieve the height of the text box content; you could write an expression that either scrolls up or doesn't depending on the text height.
Tim Jansen
on Jul 27, 2016 at 6:51:05 pm
thank you but sadly i can't use that one because i'm still on cc2014 (12.2) and that expression was added on v13 i think. i can't seem to find anything that'll help me.
would it be at least possible to automatically adjust the font size if the text is bigger than my text box. so if the text is bigger than my text box, the font size gets smaller so that the text will fit in the text box then?
tim
Kalle Kannisto
on Jul 28, 2016 at 6:52:14 am
See the beginning part of this thread for ideas for some alternate methods:
https://forums.creativecow.net/thread/227/11549
You can get it to work (roughly) by character count.
