Animating a dotted line with varying distance between the dots.
Flogan Van Uebel
on Jul 23, 2016 at 3:45:40 pm
Look at the movement curves of the ball in this guys tutorial:
What I want to do is to create a dotted line like that, where I have control over the distance between the dots, and their position along the path.
I need the effect to show how an object changes it's velocity along the Z-axis due to gravity.
Thanks in advance :)
Edit: I thought of a way to do it, but it involves creating 150 animated shapes... Any help with automating the process would still be greatly appreciated.
Greg Gesch
Re: Animating a dotted line with varying distance between the dots.
on Jul 24, 2016 at 1:32:11 am
Hi. You could use text "full stops"/"periods" (.) along a path, then use the "tracking for selected characters" - the AV setting in the text's character panel - to change the spacing between them.
Kalle Kannisto
on Jul 24, 2016 at 7:59:49 am
A particle system emitting one particle per frame should do it.
