Scaling Multiple Layers at different times
Wesley Kelemen
on Jul 22, 2016 at 12:54:26 pm
Hey Guys
I basically have one of those facebook videos that is a text slide show. It's quite long. I completed it but now the client wishes to scale the text on each layer. So something like %100 - maybe %110. Now I could go in and add a adjustment or null to each one and parent but is there a way to scale them from one effect?
So each text layer would scale %10 during it's life.
Thanks guys for any help
Walter Soyka
Re: Scaling Multiple Layers at different times
on Jul 22, 2016 at 3:10:22 pm
[Wesley Kelemen] "So each text layer would scale %10 during it's life."
You can do this by adding an expression to the text. Alt+click the Scale property stopwatch and enter the following:
value*1.1
Once you've done this to the first text layer, select its Scale property in the timeline panel, then Edit > Copy expression only. Then you can multi-select the other text layers and paste.
Walter Soyka
Wesley Kelemen
on Jul 22, 2016 at 3:30:18 pm
I think this might be my best option. Seems pretty simple thanks a lot! Saves me mucho time
Wesley Kelemen
on Jul 22, 2016 at 3:52:14 pm
I put value*1.04 in and nothing happens. The scale percentages turn red and thats it. No error just nothing happens
Walter Soyka
on Jul 22, 2016 at 4:36:30 pm
You're increasing the scale by 4%. For smaller initial scale values, the difference may not be noticeable. Increase that number as needed.
Walter Soyka
Wesley Kelemen
on Aug 1, 2016 at 1:05:05 pm
Still can't get it to work... I'm not too familiar with expression but I alt click the stopwatch which opens up expressions..
then I skip to the next line and paste value*1.1. Press Enter then go to preview
Then nothing happens..Am I missing something?
Kalle Kannisto
on Aug 1, 2016 at 1:12:31 pm
Delete the expression that gets inserted automatically and replace it with the new one.
Wesley Kelemen
on Aug 1, 2016 at 1:15:44 pm
Still nothing....
