RGB Glitch or RGB Offset
Dada Kräuter
on Jul 21, 2016 at 11:44:22 am
Hello, :)
Every video that I have watched to how to make RGB glitch or RGB offset effects shows that you need to make 3 layers, first red then green and then blue and change positions... But is there any way to offset colors without making different colored layers?
Best regards,
DADA
Kalle Kannisto
Re: RGB Glitch or RGB Offset
on Jul 21, 2016 at 6:46:39 pm
Video Copilot Twitch:
https://www.videocopilot.net/products/twitch/
Dada Kräuter
on Jul 21, 2016 at 9:12:37 pm
There is no way doing it without third-party plugins?
Walter Soyka
on Jul 21, 2016 at 9:49:25 pm
Not in a single layer.
Walter Soyka
Joe Clay
on Jul 22, 2016 at 3:47:26 am
You can, but only with one color fringe. For example you can try this:
1. Apply Effect > Channel > Shift Channels
2. Set Take Green From and Take Blue From to "Full Off"
3. Add Effect > Distort > Transform and shift the image around using position
4. Add Effect > Channel > CC Composite and set it to screen
5 Add another Transform effect and shift the image back so it mostly fills the screen
That'll leave you with a red fringe. While it's not exactly the same as shifting the three channels, it has a unique look.
You can also add an expression to the second Transform's position like this:
pos = effect("Transform")("Position");
x = pos[0] - 1830;
y = pos[1] - 2442;
[value[0]-x,value[1]-y];
Reset the first Transform in the stack and change 1830 and 2442 to the original x and y position of the first Transform. That way when you move the first transform around, only the fringe layer shifts around. I hope that helps. I feel like there's got to be a way to get all three to fringe, but I can't figure it out.
Joe Clay
Workbench.tv
Dada Kräuter
on Jul 22, 2016 at 10:09:13 am
Thank you all for your help!
Joe Clay
on Jul 22, 2016 at 3:14:28 pm
No problem! Good luck!
Joe Clay
Workbench.tv
