.aep projects default application problem
Milos Ristoski
on Jul 17, 2016 at 10:57:18 am
I installed After Effects CS4 on brand new computer and everything was fine, then i remembered that I have some old projects created in After Effects 7.0, so I installed the 7.0 version. Now when I try to open the AEP projects the default is After Effects 7.0, even when right click - open with - after effects CS4, I got After 7.0 starting. I tried changing the default opening program, but when I select CS4, navigate to program files/etc. it goes back and only After 7.0 is showed.
