Every sixth time it turns on Expression
Emmanuel Roba
on Jul 12, 2016 at 1:46:00 am
I have this problem so as it goes:
I have this expression from Dan Ebberts the expression maker and i'm trying to modify this code from the "Audio Beat Counter" Tutorial http://www.motionscript.com/design-guide/audio-count.html. I want it to count up to 6 then go back to 1. But every time i try to modify the code i get an error
threshold = 40;
audioLev = comp("Main").layer("Sound Keys").effect("Sound Keys")("Output 1");
above = false;
frame = Math.round(time / thisComp.frameDuration);
n = 0;
while (frame >= 0){
t = frame * thisComp.frameDuration;
if (above){
if (audioLev.valueAtTime(t) < threshold){
above = false;
}else if (audioLev.valueAtTime(t) >= threshold){
above = true;
n++;
frame--
n
Also I need a used a second expression as a trigger but no dice aswell
n = 6;
slider = effect("Slider Control")("Slider");
if (slider > (n - index)) 100 else 0
Kalle Kannisto
Re: Every sixth time it turns on Expression
on Jul 12, 2016 at 6:32:39 am
For the first one, you should be able to replace the "n" on the last line with "1+n%6".
What do you want to accomplish with the trigger? The expression should work just fine.
Emmanuel Roba
on Jul 12, 2016 at 12:28:30 pm
Thank you Sooo much!
The trigger is the thing i want to turn when it hits 1 then turn off when it hits another number.
Its because i'm picwipping to an invert effect, and it turns on all the time when I set it to 1
Kalle Kannisto
on Jul 12, 2016 at 6:05:05 pm
I would try changing ">" to "<" (or switching 0 and 100).
Emmanuel Roba
on Jul 12, 2016 at 9:37:33 pm
Thank you once again!!
I did some java script learning and I replaced the ">" with a" ==" it seemed to do the trick.
Replying for future use.
