After Effects Numeric Fields as a Calculator
William Saviola
on Jul 11, 2016 at 4:38:42 pm
Since version 2015.3 the calculator when used in numerical fields does not work.
Why have adobe removed this function.
Does anyone know?
Walter Soyka
Re: After Effects Numeric Fields as a Calculator
on Jul 11, 2016 at 4:45:04 pm
[William Saviola] "Since version 2015.3 the calculator when used in numerical fields does not work. Why have adobe removed this function. Does anyone know?"
It's still there and working correctly in 2015.3. Perhaps you should try resetting your preferences? Hold Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) while Ae is starting.
Walter Soyka
Kevin Camp
on Jul 11, 2016 at 6:10:24 pm
I have noticed the same issue (Ae 13.8, OS X 10.11.5).
It's seems to be specifically the size attribute (comp size or solid size). layer attributes, like position, scale etc, behave normally.
I did try to rebuild the preference file, but no effect.... I'm thinking it's just a bug.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Walter Soyka
on Jul 11, 2016 at 7:52:38 pm
Well, how about that. It seems to be any dialog box. I've filed a bug report; please consider filing one also.
Walter Soyka
William Saviola
on Jul 11, 2016 at 8:55:46 pm
how do you file a bug report?
Walter Soyka
on Jul 11, 2016 at 8:56:46 pm
[William Saviola] "how do you file a bug report?"
http://www.adobe.com/products/wishform.html
Walter Soyka
Michael Szalapski
on Jul 12, 2016 at 2:42:09 pm
The bug only happens in dialog boxes. It still works in properties.
Also, if you press = in the dialog boxes it'll make it work too (in most cases).
- The Great Szalam
William Saviola
on Jul 12, 2016 at 3:56:31 pm
oh you have figured it out
thank you so much!
