Creating Faux Hair Edge-Effect form Puppet-Pined Layer
Aubrey Boles
on Jul 5, 2016 at 10:15:22 pm
I've got an IK rig, using Shape Layers Puppet Pins linked to null objects parented to various parts of a creature's skeleton.
http://imgur.com/W1Olbuh
I want to make the edges rough, roughly similar to hair. This doesn't need to be particularly accurate, as the image will be displayed behind some cloth (Giving the impression of a shadow passing behind the cloth). The Roughen Edge effects would be fine if the layers where not animated, but the shimmering the effect causes doesn't look as good as I would like. I've tried using the CC Hair effect, but to no avail. Anyone have any ideas?
(The rig consisted of a skeleton rigged with DuIK, with Puppet Pined shape layers acting as musculature. I plan on using this "hair-effect" on each of the relevant muscle layers to create the idea of short hair.)
Aubrey Boles
Re: Creating Faux Hair Edge-Effect form Puppet-Pined Layer
on Jul 6, 2016 at 5:12:19 pm
I just talked with a friend of mine, and he recommended I switch the order of effects to have the Roughen Edge" before the puppet pin. That works pretty well for most of it. He also pointed me to this: http://aescripts.com/smart-precomposer/ to precompose the shape layers.
I figured I'd share the info here for others.
-Aubrey
