Rendering 2 Projects into 1 .AVI
Or Ellenbogen
on Jul 5, 2016 at 12:07:10 pm
Hey Fellows, How Are You?
So... I got 2 projects:
1. Logo intro of my business
2. The clip
I open the clip project and added the Logo intro into the composition, now I want both files to be exported into one .AVI \ .MP4 \ Whatever format so I can upload it as one piece.
How do I do that?
Thanks ..!
Dave LaRonde
Re: Rendering 2 Projects into 1 .AVI
on Jul 5, 2016 at 4:14:30 pm
Easy: create a new project. Import the two projects into it. Make a new comp. Add the main comps from the two projects to the new comp. Render.
You're done!
Dave LaRonde
Promotion Producer
Or Ellenbogen
on Jul 5, 2016 at 5:47:01 pm
I've tried it Dave,
but when I go to Queue To Render... I gives me 2 seperated files to render and the Output is diffrent for each one of them. That splits the 2 files into 2 diffrent .AVI files that does not include each other.
You got a solution for that?
Dave LaRonde
on Jul 5, 2016 at 5:58:13 pm
Well then, you didn't do it properly. This has been a feature in AE since I first started using it, Version #3. Read the instructions over again and try again. There's absolutely no reason why you can't nest two comps into one comp and get one rendered file.
Dave LaRonde
Promotion Producer
chris brett
on Jul 5, 2016 at 6:48:07 pm
Hi Or
--- when you say 'projects' it sounds like they might be project files ( ie not rendered )
--- if this is the case and you are short of time just render them out then use as 2 seperate layers in a new project file -
--------------------- chris--
